William_H
Yes the bow winching eye should be the strongest point. Usually the hull is really thick at the the bow. I would not bother with cleats etc as I think they will just pull off damaging the GRP in the process. I woulod say that the boat should be pulled in a straight line in the direction it is pointing. It looks like the hull is essentially upside down so it is possible some of the mud will fall out of the cockpit. It would be really helpful if you could lift the stern in some way perhaps with buoyancy drums when the tide comes in. Difficulty would be gatting an attachment at the stern.
In any case if the tide comes up quite deep it might be practical to attach drums to the exposed part of the hull and close to the hull so that the buoyancy works to slowly lift the hull. Not much good if the water is not more than 3 metres deep of course. I wish you lots of luck but suspect it may all fail. olewill
