Looks like a bit of rope for that plus to lower and raise it.It looks very PBO sketchbook to me. I would add a long drop nose pin across the cheeks of the outboard end to lock it in the upright position.
I assume looking the picture posted by the OP that when the outboard is lowered down into position, that it will be vertical ready to use. The 'support legs' are fixed at different centres.If I had been designing the bracket post by the OP, I would have made it as a Pantagraph so it can be lowered with the engine retaining its proper orientation when lowered
It is pantagraphed....the uprights are actually two separate tubes of the same length but offset and are individually on pivotsIf I had been designing the bracket post by the OP, I would have made it as a Pantagraph so it can be lowered with the engine retaining its proper orientation when lowered
It would be nice to see a picture of it in the lowered position but to me the pivot points look correct in that the aft upright becomes the lower 'upright' and the bracket that the engine is bolted to swings to the correct position.It looks like the pivit points are not in the correct position for a Pantagraph to function correctly as the lengths of the Pantagraph need to be the same length to maintain the correct angle for the outboard bracket
A picture showing it in the lowered position would clarify the operation.
