Alex_Blackwood
Some info on Vishay Thin film Non resettable fuses.
Fuses | Vishay
I hear what others are saying and first thoughts were that it was not a fuse. However looking at the diagram, I will reiterate that there is no diode in the charging light circuit. There can't be, current has to flow both to and from the alternator for it to work! The fact that the charge light lit when the device was shorted may in its self be misleading. Do the other lights illuminate as normal or not? Do they work only if this device is shorted? It maybe that the temp. sensor would need to be "shorted" to test. As for using a multi meter on continuity as suggested in #12. As I have previously said if the component is in circuit you can get misleading readings through other components.
Sorry I can't be of more help in IDing the device but almost impossible online.
I also suspect that some posters are not reading what has already been posted.
Fuses | Vishay
