CAPTAIN FANTASTIC
Naturally, a bowthruster is a nice thing to have to get in and out tight spots. However, do they create too much drag?
Two big holes instead of a smooth hull form. It all depends on your priorities.Naturally, a bowthruster is a nice thing to have to get in and out tight spots. However, do they create too much drag?
Forty eight years.I wonder how long you have to wait before fouling fills up the tunnel and fairs it off for you...
Frontal area of the tube holes on my boat looks like a couple of percent of the total hull. Mine's well faired in but say the drag coefficient is two or three times that for the rest of the boat, then the increase in friction drag will be a few percent. But as the speed approaches hull speed friction drag becomes less significant. My guess is the effect will be similar to that of a fixed-blade prop and will be more significant at low speeds.Naturally, a bowthruster is a nice thing to have to get in and out tight spots. However, do they create too much drag?
No more lee bow effect?On the plus side, any cross currents will go straight through the hole.
A small price to pay.No more lee bow effect?
Like the thruster ,Hate the drag.
Always wondered if you could have some kind of outer door like torpedo tubes .Would be fun giving the order.
Or a cover that pivots up into place with the force of forward water flow but then drops clear of the tunnel at low speed.
How about a lightly sprung Venetian blind set up which has just enough force to open when no forward flow but shuts under way.
Or buy a retractable bow thruster in the first place
