[70521]
Yes, they are fantastic and I first learned to navigate over 35 years ago.Do you use Waypoints.
with a plotter one can blob a wp instantly then goto obviously checking that there are no nasties on the track
X tide wp add miles far better the compass coursesimilar......
Plan by looking at the paper chart,
check the plotter chart,
stick some 'marks' on the plotter chart,
sail/motor using the marks as a guide to shortest distance between points missing 'nasties',
keep a half hourly log if not in sight of land, hourly if in sight,
Too much time can be spent below checking chart and boats position with landmarks imho.
S.
Try crossing the Thames heading from Burnham on Crouch to the Solent without them we had 34 waypoints needed to avoid mud and sand banks. On the Atlantic crossing we had three.
X tide is X tide & makes + 10 mile difference on a X channel tripsurly that depends on where you put the waypoint
In the early days of GPS I used a Garmin 128 with Differential gps (it was used for wreck fishing) I used lots of waypoints as a means of finding my way up a twisting drying out river in the dark, it was invaluable, I could not have done it without waypoints! some of the waypoints were less than 50 yds apart! although passing under leccy pylons could throw the diff corrections out a bit.
Of course, and it has nice colours! still need the waypoints altering in line with the shifting shallows unfortunately.Yes, but nowadays with a plotter you would do the same thing by keeping the little boat in the right place on the screen.
I find it useful to set a 'waypoint' in the centre of a compass rose. The lat and long of the compass rose is printed on the chart and you have a 360 degree 'protractor' encircling it. The GPS will show you the bearing and distance from it and to plot a fix just lay a ruler from the centre of the compass rose across to the desired bearing and mark the distance along it.
I find this easier and less prone to error than plotting using the lat and long scales.
those who busily (and rightly) draw in their course line and the relevant tidal offsets onto charts.
I really don't care what other people do, but nor do I consider myself to be anally retentive because I put in a route for each day's sailing, any more than those who busily (and rightly) draw in their course line and the relevant tidal offsets onto charts. It is the work of a minute or two on a plotter, and gives me the chance to look at where I will be going in some detail. The whole purpose of the exercise is to have a pleasant and safe passage. Back in the '70s, when we crossed the Thames Estuary, you had to sail up to each buoy just to read the name and confirm your position, but nowadays a track will save me the effort.
Except when under engine and therefore following my track exactly, I always regard waypoints and tracks as flexible options. In my mind I am usually making calculations about the combination of my boat speed and the wind and tide conditions, saving a mile or so here and perhaps giving some distance to the tide there, so my actual course is a compromise between the shortest course and what will be quickest or least likely to be affected by a change in conditions. Just watching my boat on a plotter screen does not give me the chance to sail in this manner, though I am happy to do so when conditions make it useful, such as when we left Treguier this summer and had to weave between the rocks when the transits were scarcely visible.
