Do you adjust your furling jib halyard during the season .
LONG_KEELER
21 Jul 2009
East Coast
Just interested.
I'm wondering if mine is worthy of my posh new Spinlock clutch or just tie it off .
When I had hanked jibs, apart from up and down I adjusted them quite a lot with satisfying results.
I don't touch mine all season - once it's set up at the seasons start - not too tight - no need to adjust.
Halyard tension is quite important in terms of sail trim - I cant see how leaving it the same all year round can be helpful
It's not particularly good for the sail either
Also it's recommended (if you adjist the backstay while sailing) to tighten the backstay BEFORE you tension the jib halyard.
I wonder how many boats actually have a way of adjusting back stay tension easily?
I slacken off the halyard when leaving the boat and play with it a little when the sail is completely out.
Prw
I should think most AWBs with the currently fashionable 19/20 rig, in vogue since mid-90s. Ours has a manual hydraulic pump and it makes a big difference.
Aside from that, most designs with any racing pretensions including (to my knowledge) sigma 33, 36, 362 and 38, I think all J-sprit boats.
If you tension the halyard to the point you are comfy with and then tighten the backstay, you are super-stressing the sail. So I was told, and think it makes sense. Also, then releasing the backstay is enough to consider the sail relaxed, but you should ideally remember to do it before you furl.
Prw
Depends whether halyard tension is much less than forestay tension or not.
If you dump the backstay and apply a lot of halyard tension, all the load is on the jib luff and not on the wire. But generally the forestay takes the main tension, not the jib luff, so cranking on the backstay puts little extra onto the luff rope of the jib. It does however straighten the luff so has a flattening effect in the jib.
Just interested.
i adjust the halyard tension and car position each time i use the sail as the wind strength changes. just because it's a furling sail there is no need to set it badly.
With a Luff Groove sail on a furling - please explain what advantage there is in different tensions ? Given that most furling gibs are cut to furlers and not same a hanked on ... second you have a clean foil entry to the sail unlike a hanked on ...
I make sure mine is taut all season ... and that's it. If it was my race boat - sold on now - that's different as its hanked on anyway.
