DIY wind speed and direction
slawosz
26 Sep 2018
London
Hi,
inspired by recent RPi topic, I wonder if someone with proper electronic knowledge would like to collaborate on open source wind speed and direction device. There are already some guides and examples all over internet, it just need design of the moving, 3d printed parts (I can do that), designing the hardware and circuits (I can do that, but have no experience so would appreciate help as I know there are people with knowledge here) and writing or copying (if license allows) already existing software, ideally on something like Arduino Nano (I can do that). What do you think?
GHA
26 Jun 2013
Hopefully somewhere warm
Hi,
There was some discussion over on the openplotter forums, they're more into that kind of thing over there.
One thrad, pretty sure there are others
Ultrasonic Anemometer
TSB240
17 Feb 2010
I have been looking at using the Onwa KW 360 for a repair project today.
I assume this is ultrasonic as it has no moving parts.
If you scroll down on the linked page below you can download their Windows software for presenting the output including wind speed, direction, barometric pressure and temperature.
Can you reverse engineer their MHU and make it for less than £350?
KW-360 - ONWA Marine Electronics Co. Ltd.
Refueler
13 Sep 2008
Far away from hooray henrys
Looks a nice piece of kit .... but it is wired which some may not like.
Would be nice if it was Android capable as well ... but seems only Windoze so far. I also assume - it needs its own SW to sort the info into display.
thinwater
12 Dec 2013
Deale, MD, USA
sail-delmarva.blogspot.com
If the ribbon could change color depending on wind strenght, that would be something!
  • Straight down. Very light winds.
  • Drooping just a little. Uncover the sails and head out.
  • Horizontal. A nice breeze.
  • Snapping at the ends. Reef.
  • Gone. Lower sails. Now.
In fact, with yarn it pretty much works that way. And look at the water.
The only use I have for electronic wind is if it interfaces with the autohelm. Otherwise, it's kind of obvious.
Refueler
13 Sep 2008
Did you know that the Aero Windsock has the orange / red bands that when originally designed and made in the material and weights etc - they would give indication of wind strength by the bands ? Trouble is todays windsocks fail to do it .....
GHA
26 Jun 2013
Luckily we are allowed both. :cool:
Never had wind sensor data until recently, then splashed out on a CVC-7, need some accurate data for a Pypilot to do it's best anyway, and very handy with opencpn watchdog for alarms single handed.. Just fantastic. But no more bragging bout 60Kts in few minutes...the numbers don't lie :giggle:
GHA
26 Jun 2013
Volmet is useful for that, if you have an HF receiver. Can be very handy.
Kelpie
15 May 2005
Afloat
When you're cowering under the spray hood in 45kt and hailstones the size of grapes, using the engine to counter a dragging anchor off a lee shore, it's very nice to have a good wind instrument. Impossible to steer by any other means in those conditions.
It's only happened to me a couple of times but it's changed my attitude to the wind instrument. I now view it as absolutely essential.
Beneteau381
19 Nov 2019
thinwater
12 Dec 2013
Deale, MD, USA
Mostly I was joking. My PDQ has a full suite. But I never motored up against an anchor. Never felt the need, and never felt it took strain off the rode in a reliable way (if you are thrown back, mostly likely side to wind in the process, the resulting impact force will be worse than relying on a good, elastic rode and snubber).
Instead, I would have preemptivly set a second anchor in a V. Takes only a few minutes with practice. I have done this a good many times, always worked (and I did have an inch of hail in the cockpit once).
BobnLesley
1 Dec 2005
Aground in Yorkshire awaiting a very high tide
It doesn't need to, there are only three wind speeds - not enough/that's about right/time for a reef - and if you can't judge those without an electronic screen, you probably shouldn't be out on your own.
Kelpie
15 May 2005
Afloat
I've only done because I was already dragging. Least worst option at that point.
And if it had been forecast, then I wouldn't have been there.
Having dragged a few times this summer in the Med, generally due to unforecast sudden changes in wind speed and direction, I've been extremely glad to only ever had one anchor set at the time. In a crowded anchorage there's a lot to be said for simplicity, and being able to get out of there asap. It might be someone else who is dragging...
slawosz
26 Sep 2018
London
Occasionally I have a brain storm and look through home based Weather Stations with WiFi displays ..... and wonder if could be adapted to on-board use ?
I think it should be quite an easy job.
On the OpenMarine forum there are rummors about £130 unit. But not sure how well suited they are for sailing.
According to the rules, the sock is fully extended at 15 knots which is crosswind limit of small aircrafts.
I can't live without gizmos. I used to put 2 reefs on force 1 and hoist spinnaker on force 7 before I got my wind instruments!
