WayneS
Time to ask for your input again.
Up till now the only way for me to find out how much fuel I have in my tank was to push an old fishing rod down the filler. Having already broken a piece off in the tank I now think that a better solution is called for.
I am loathe to spend too much, or make any holes in the tank (cos holes mean leaks....) so am looking to have a simple clear plastic pipe up the side of the tank....
Not wanting to make holes in the tank, I am looking to just add a "T" piece into the outlet (After the shutoff tap) with the tail pointing upwards, to which I will attach some pipe. If possible I will feed the top end back into the tank but if not possible I will just make sure that it extends well above the tank.
However, my big concern with this is....will this pipe then become the path of least resistance when the fuel pump kicks in, so that instead of taking the fuel from the tank, it sucks is down my new pipe and then ends up sucking air. Am I right to be concerned about this or am I just being silly.
If this is a problem I suppose that I could just add a shutoff valve at the top or bottom of this new pipe and only open it up when I what to check the fuel level.
I'm sure that I have not explained things very clearly but I hope that you get the concept.
Thanks in advance for your help.
Cheers
Wayne
Cheers
Wayne
