Daydream believer
With due respect I feel that you misunderstand.Makes no sense. How could the loose car somehow pull itself away from the force with no force on it? Do a force vector diagram and you'll see, the horizontal companant has to be outboard.
A curved track allows for moving the block inboard which the dyneema won't but that's no great hardship.
If one had a straight track the shortest distance would be on the centre line of the boat. So if one sheeted in the sail tight then the sail would automatically align with the centre of the boat. In light wind that would be useless. The more weight one put on the dynema the more it would bend towards the sail & the more it would force the sail to the centre. To move the sail outwards it would be applying extra tension to the sheet & that would not work.
The curved track maintains the same tension as the sail passes through the tack.
If i am wrong tell me why virtually all the cruisers & most dinghies with ST sails that are on the market have a curved track?
Do you honestly think that if a straight track worked they would go to the expense of a curved one?
