pcatterall
Being the proud owner/builder of a brand new fuel polishing system I thought I would give it a go and report back!!
I did have 5 gallons of the red stuff which I had rescued after cleaning my tanks, this was the stuff from the bottom and very black.
This has settled over the last 6 months, there was a darker layer on the lower 3" of the container.
I did my first filter using the hose only part way into the tank thus avoiding the nastiest of the black stuff. I compared the 'filtered' fuel with that in the top half of the original container. There was no discernable difference in colour.... not quite gleaming ruby red, slightly brown but not bad ( I may try some photos!).
I continued filtering with the pipe held just above the mucky stuff in the bottom.
I then poured the bottom layer into a glass container ( it was opaque when held to the light) I then filtered this into another glass container, it seemed only marginally clearer, I filtered it 5 times in this manner and it seemed to get clearer every time untill it became as clear as the first sample.
So assuming that colour is at least a guide to cleanliness ( and it may not be the whole story) really dirty fuel took five passes to clear it. This concerned me a little because in a 'boat situation' the filter only gets one pass.
Does this imply that if we leave our boat in a nice calm situation for a week or more then start up and drive away then the potentially dirty fuel ( which is the first to be drawn up) will not be filtered as well as it should be?
The filter element I used was 5 to 7 microns and my ( before this test) understanding was that ( in theory) any particle over that size would be caught in the filter which would do that job until the filter blocked or was changed. I recognised that this was 'in theory' but didn't consider that 5 passes would show continual improvement.
These results suggest (to me) that a polishing regime should be as follows.
Ideally after the boat has been 'steady' for a day or so 'Polish' the lower 5 gallons into a seperate container, if the fuel looks mucky then dont return it to the tank but circulate just the fuel in the container through the filter until it is clean.
I recognise that there are practical issues here with pipework ( connections on and off or valves) but the alternative would be to polish the contents of the whole tank 5 times in order to be sure that the small really dirty portion was clean.
This trial has certainly made me think again on fuel issues.
It WAS a cheap CAV type filter so possibly a more efficient one would have cleaned the fuel on the first pass??
Would there be an advantage in just using the polishing system ( at least for the bottom few gallons) prior to starting whenever the boat has been standing a while? Just one pass would at least mean that all the bottom gunk would be distributed over the whole tank rather than it all being drawn through the filter when you start up.
