vyv_cox
Unfortunately, it says "does not ship to the UK"!
That's the URL of the original search by Owen. Google the same title words and there is an alternative supplier, priced in GBP.
Interesting thread. If Aerogel or similarly effective insulation is used, would it be possible (by increasing its thickness far beyond usual standards) to reduce power-requirement to within the capacity of a small battery and solar recharging?
My thinking is that most yachtsmen graduate from the smallest and simplest (non-electric) cruising boats, straight to much bigger, more elaborate set-ups, where fairly hefty and complex 12v supply, wiring, maintenance and recharging is necessary...yet refrigeration is still typically only available for the duration of each cruise, when regular charging is available...
...whereas (planning ahead) I'd quite like to keep my first cabin-boat largely non-electric, but refrigeration can't be achieved without some power...
...so, if I was to regard the fridge as only a tiny place of long-term storage for a handful of foods/medicines which won't last at summer cabin temperatures, could the 20-litre space theoretically allotted to a conventionally power-hungry 12v cooler, be stuffed with insulation to allow, say, a 4-litre core to operate continuously without the limiting power-consumption and noise that yachtsmen are accustomed to?
If remember this previous thread correctly, skipper_stu is in the Med and running a fridge entirely off solar + house battery: http://www.ybw.com/forums/showthread.php?432158-On-the-hook-in-the-Algarve-and-solar-panelsInteresting thread. If Aerogel or similarly effective insulation is used, would it be possible (by increasing its thickness far beyond usual standards) to reduce power-requirement to within the capacity of a small battery and solar recharging?
The lid will never fit perfectly without a gap, so there will be losses there. But I read recently that opening the lid for short periods doesn't make that much difference.The heat just needs to be kept out. Of course problems arise with things such as a lid where there is always going to be sub-optimal insulation and you are going to open it from time to time.
Excuse me, you're right.I guess you mean 4 to 5 inches?This thread inspired me to read up on the subject a couple of days ago, and it looks like most people are using 4 or 5 layers of 25mm (1") of builders merchants insulation - i.e. 4cm - 5cm total. unquote
