eddystone
Getting extremely frustrated waiting to relaunch because of continued failure of engineer to do promised work, i.e. fit owner supplied shaft seal and investigate suspected faulty head gasket. Can't do anything about the latter but how difficult is it to do the volvo seal? Looking for explanation in ikea self assembly rather than engineer speak; level of skill? I'm Ok at undoing nuts and bolts and putting them back in reverse order but if it involves anything fancy to check shaft alignment I'm out. Also lack skills to diagnose why there is some reason it is spraying after less than 3 years (lips damaged when cutless bearing replaced becuase said engineer failed to use lips protector/crustacean action etc)
