PuffTheMagicDragon
In the parallel thread to this one someone with ties to aquarius coatings states that the reason 'the others' failed in their attempts was because their epoxy was too impermeable to water.
I don't think the epoxy erodes so much as water gets in to it and the copper corrodes. When it does that the low strength epoxy allows the copper to become exposed.
So if the epoxy is, by inference, slightly permeable to water it can't be waterproof.
The way I think it works is this. There is a large percentage of included solids (copper)in the matrix (epoxy). This means that the amount of epoxy between adjacent copper particles is relatively thin. Thus, when the exposed copper is oxidised and eventually dissolves away, the surface that is left is composed of an epoxy matrix with very thin walls surrounding voids. It is thus very friable and will erode away with relative ease, especially with a flow of water over it. Think of a block of concrete with the aggregate removed.
This might also explain the improvement in performance after a couple of months' use in the sea and also after rubbing down lightly with wet-and-dry.
