electrosys
How to make 'de-ionised' water, without a pH meter ...
First, collect water from a dehumidifier - this will undoubtedly contain many dust particles, as well as being ever-so-slightly acidic from the absorption of carbon-dioxide from the large volume of air which has passed through the machine.
So, pass this water through a paper filter (a couple of paper towels would be ideal) into a plastic or similar unbreakable vessel.
Then, place the vessel containing the filtered water in a freezer, and when approximately 50% of the water has turned to ice, remove the ice and allow it to melt in a clean container. This water will then probably be near enough pH7 for most purposes - however, if you want to be absolutely sure, then recover the ice at 75% instead, melt and re-freeze, recovering again at 75%.
This process is known as fractional freezing, which is a parallel process to fractional distillation - with each pass through the process, the recovered product becomes increasing purer.
Of course, I couldn't possibly comment as to whether fractional freezing is an equally viable (and perfectly legal) method of extracting alcohol from hooch ...
