Disposing of old two stroke petrol mixture ?
Hi Richard,
I have vast experience with stale fuel issues in small 4 strokes. I cannot comment on larger outboards as i have limited experience. 75% of the problems with engine i have in are due to stale fuel.
Here are a couple of examples. I ran a rebuilt motor with a brand new fitted carburettor in a test tank with no issues whatsoever. I put the engine in the rack . Three weeks later i tried to start the motor and it wouldnt even fire. I took the bowl off the new carb and the fuel was yellow/green in colour. Flushed the carb drained the tank and refilled with new fuel and fired first pull.
I sold a chap an engine again with a brand new carb (i fit all my hondas with new carbs) test ran it and he took it away pleased as punch. A few weeks later i had an angry e mail saying this and that and the motor wont run etc. I asked if he had put in fresh petrol . He said yes. So he bought it back and it was stale fuel again. Refilled it with fresh and literally first pull ran sweetly. It turns out the fuel was about 6 months old in a sealed can. So i can categorically tell you from a lot of experience modern engines do not like stale fuel.
My convertible car and both my lawnmowers sit from November to March every year with the same tank of fuel and both start first go in the Spring.
Two stroke is different obviously as the petrol can evaporate and the mixture could get too oily and foul the plug. Just add it to a larger batch with the correct ratio.
Richard
Petrol does degrade over the winter. Different engines seem to react differently to it. I have an old (late 1990s) 2 stroke 2.3hp Johnson outboard for my tender that is always difficult to start at the beginning of the season. I usually persevere and use the fuel in the tank. When I buy new petrol it miraculously improves. I also have a 2stroke 40hp Mariner on a rib that doesn't seem to worry about using last years petrol. Both use the same 50:1 mix, and are stored in similar dark conditions in the garage. The tender outboard gets a lot more use than the rib, so it's petrol doesn't lie around as long as rib engine petrol. I wouldn't attempt to use fuel that has been laying around for a longer period and has distinct smell that is totally different to new petrol.
We had Nigel on these forums until a couple of years ago. He said that petrol doesn't go off. (unless exposed to daylight)
He was a fuel blender. I believe Nigel.
These people who have problems with "stale" fuel. Could it be that the oil is settling in the tank (and the float chamber) and the engine is being fed a very oil-rich mixture?
Could that be why draining the tank and flushing the carb solves the problem? I wonder if putting the drained fuel back in, after a shake up, would see the motors starting easily.
I think you will find that Nigel Luther said a little more than just that.
He recommended, much as I do, that it should be stored in tightly capped cans to prevent loss of lighter fractions and minimise contact with air as well as minimising exposure to light.
(He last posted on these forums nearly five years ago)
The oil is completely dissolves in the petrol . I dont think you will find that it will separate any more than the solute will separate from the solvent in any other solution.
We keep going round and round this one.. I will only repeat what the outboard engineer (with 60+ years experience) I use tells me - "never use last years fuel". He blames the newer additives..
I can't see any reason not to chuck it.. the stuff only costs a quid and a bit a litre, and I'd rather be able to rely on the outboard starting, than save a couple of quid....
In response to the OP, as per one of the other replies I usually slip it into the oil tank at the tip when they aren't paying attention, or just put it in a bag and put it in one of the skips...
It seems that some engines are more sensitive to old fuel than others. If you have a petrol car, adding old fuel to make up to a full tank seems to cause no problems. Otherwise, stick it in other engines a bit at a time.
As long as it's not actually jellified I just stick it in any old four stroke engine of 'a certain age'. Neither our Ami8 nor either of the Quatrelles have ever complained. Out of an abundance of caution I'd be a little more hesitant about sticking it in a modern petrol engined car but then I Know nurthing...
Do you have any other insight into why I haven't had any problems with stale fuel
It's already at 50-1 mix, pour half a gallon in every time you put 10 gallons in your car you will then have a 1000-1 mix. Your car or cat wont notice. It's what I do every year with what I have left over at the end of the season then use new stuff in the outboard next year. It's easier than trying to get rid of it.
Spot on. No engine is going to notice that level of dilution. I've never known petrol go off either. My mower started about 4th pull the other day on the remains of last summers fuel in its tank.
Disposing of petrol at a council oil disposal point is an absolute no no. That creates a massive risk to other people disposing oil and also to workers there. Very naughty and dangerous.
Tim
No .
some people seem to have more problems than others. Some engines seems to be more susceptible to difficulties.
I always store the outboard 50:1 2 stroke mix from one year to the next but I do so as already outlined and I only keep full metal cans to minimise the contact with air and exposure to light.
Ever since I had to strip and clean a carb on a windy night in a busy river estuary I filter it before use. I also mix it about half and half with fresh.
Anything in excess of the two full (metal) cans I put in the car or use for the Seagull or the Flymo. Its these small "left overs" that have not been stored like the rest that cause any problems I encounter.
I doesn't matter much if the Seagull is unhappy because I can row the dinghy and it does not matter at all if the Flymo wont start because I can use the electric one or let the grass grow but if the main outboard plays up entering a busy river estuary with loadsa other yachts, mobos, car ferry, hydrofoil, chain ferry and a strong tide its rather more serious and I take whatever precautions I can that might avoid any such difficulties arising again.
As a motorcycle technician, I can PROMISE the 'non believers' that modern petrol most definitely 'goes off';-) How quickly this happens involves many factors. I will also confirm that adding small amounts added to a tank of good fuel will NOT damage an engine in any way. If too much is added, the only issue would be 'POSSIBLE' damage to the cat. However, even this if done in small amounts, is not a problem.
The only time i wouldn't recommend this, is with high performance, tuned engines.
Northern climate?
I've had stale fuel which seems to have stopped engines working.
But only very old fuel, which has been stored in vented tanks for more than a year.
I'm talking about 'project' bikes which have not run for 5 years.
It smells very wrong. Can't describe it.
One of my italian bike manuals says old fuel 'may turn sour' which does not describe the smell, its more of a sweet chemical fruit thing...
Fuel left in a small carb will tend to evaporate, which can cool the carb inducing condensation. This puts water droplets in the carb, which is IMHO the most common reason for small engines not to start.
As for getting rid of old fuel, unless it smells really odd, chuck it in any engine without a cat and dilute it with new fuel.
Do check or filter for water, dead spiders, rust.....
If it smells really odd, put it with the old sump oil.
Well, one reason is that it can be quite hard to chuck. Our council has built a new dump and closed the old one, and there is now no waste oil tank. The place is also swarming with staff who scrutinise what you're putting in the skips, and anyway putting petrol in stuff I know is going to be incinerated does seem a bit naughty. I wouldn't have a problem with putting it in a petrol car in small quantities, but I now drive a diesel.
There are several different strands of thought here.
FWIW this is my summary.
Any fuel, petrol, two-stroke or diesel, in an airtight container will not "go off" unless you are talking about years of storage at warmer temperatures or exposure to sunlight when, I accept, it might be possible for some side-reactions to occur. Talk about lighter fractions is irrelevant ..... the container is airtight.
Fuel stored in a vehicle depends upon how airtight the system is. If it is fuel injected any evaporation of light fractions is likely to be minimal and result only from evaporation through the main tank breather. This is likely to be very limited, especially if your vehicle does not smell of fuel when standing still. The engine will run fine as there is not a small reserve in a carburettor to be affected.
In a carburettor engine, there may be evaporation through the jets and intake manifold. This will be worse with two stroke mixture which will become over-rich. Different engines will be differently affected depending upon jet size and natural ambient airflow through the manifold. Even in an engine which has high evaporation, which you might be able to smell just standing next to the motor, it is only the small amount of fuel in the carb which might be affected. Just drain that 50cc off and add it back to the main tank. Problem solved.
Some engines have minimal ambient airflow through the intake manifold. The fuel in these carbs will not go off. :encouragement:
Richard
My take is that plenty of people seem to have problems with stale fuel whilst some others seem to have no issue.
Have to say though I'm very surprised that so many people have so much fuel left over at the end of the season. Personally I'm not keen on carrying large amounts of petrol so buy a 5l can which I then use to top up the OB which takes 1.4l. It shouldn't be that hard to run down spare petrol supplies at the end of the season so that there is only a small amount left to dispose of either into the car or to be diluted with fresh petrol.
