Disposal of old Fire Extinguishers
boatmike
30 Jun 2002
Solent
Simple question, what do you do with unused powder fire extinguishers? With other types discharging them renders them harmless. Powder makes such a mess.......
I donated them to a Makerspace that wanted to have extinguishers near their soldering benches and 3D printer. Not a generally-applicable solution, I realise :)
I've heard of letting them off into a sturdy binbag. Dunno what volume the gas expands to, but it seems plausible that it might all fit. Otherwise a loose fit around the nozzle might allow the excess to escape without letting out too much powder?
I thought discharging a couple of them into a skip was rather instructive. They don't last very long!
Just be careful if its dry powder.... it gives you the poo's :)
Just discharge it into a binbag should be fine, better yet a container with a little bit of water in the bottom.
I'm quite sure tips/recycling centres will accept them
Having set off numerous powder extinguishers that have been well out of date (up to 30 years out of date), every one of them have worked as if they were in date.
why not set them off in a dustbin of water. Presumably the powder just forms a sludge that can then be more easily disposed of and the gas bubbles away?
I had the opposite of that. 4 1980s vintage extinguishers fired a year or so ago. One worked. All had just come off boats that had recently been in use.
Firing in to a skip worked fine for the one that did work.
Another alternative is just to sell a boat and leave all the extinguishers, flares, and corroded campinggaz cylinders on board.
is that why I have a TEP museum?
Not sure about the environmentals, but I fired a 1kg out of date powder extinguisher at sea, downwind. Quite a kick and quite a cloud! (no other vessels or coast in sight..)
I can vouch for them making a mess, and quite a noise. Did put the fire out though.
How about donating them to your local custom motorcycle builder? They come in handy, and then it's his problem what to do with the powder...
