Ceejay
The key is regular oil changes.
and the correct running temperature, so worth fitting a temperature gauge and changing the thermostat if the engine starts to run cool.
CJ
I have the 88bhp version of that, now with just over 5000 hours and going well. I have seen others with over 7500 hours on them. Mine is rated at max revs 3600, max contiuous revs 3400, and I usually cruise it at 2500, but every so often I give a few minutes at high revs just to avoid glazed bores or to punch against a strong headwind. I think it would be pretty hard to wear one out. As I average 100 hours or less per year I think it will last till I am 100! The key is regular oil changes.
The original example that started this thread was probably of this type - and almost certainly too powerful for the boat, so never run in the way it was designed. It is a common mistake now for people re-engining older boats to fit an oversized engine in the mistaken belief that a "bit more power" is a good thing. Helped of course by the small price (and bulk) differential between say a 14hp and a 20hp. Both will fit in the same space as an older 10 or 12hp, but in many cases the 20 will reach hull speed at 70% power so the extra is never used and the engine is run at 40% power at cruising speed.
I know that what you say is the conventional wisdom, but I for one don't believe for a minute that there is any harm at all in running a diesel engine at 40% of its rated power, or even 20% of the rated power, provided the operating temperture is correct and the engine was properly run in.
This guy, a denizen of this forum, seems to agree:
http://coxengineering.co.uk/bore.aspx
On the subject of longevity ...
My boat engine is 26 seasons old and still works fine.
No way will my car engine last 25 years without major surgery.
I have spent a fair amount of time being aerotowed by small Lycomings. That's a hard life: full welly at low speed for eight minutes followed by the fastest dive at idle back to ground which the heads can stand.
I agree that's a killer for the engines but their problem is that they're air-cooled so, when you're hauling a glider up to 2,000' or so, you've got a higher than normal load on the engine AND a lower airspeed so less airflow over the heads.
You shouldn't see cooling issues to the same extent with a water-cooled engine in an enclosed engine bay/room.
I have been doing quite a lot of research into the glazing problem and my main conclusion is that cylinder temperature is probably the most important factor. There is a close parallel in reciprocating compressors, which I have worked on extensively for the past 40 years.
If the bore is cold, certain components of the combustion gases are likely to condense on it. In time, and as the temperature increases, this condensate will form the lacquer that becomes glazing. Running an engine at low revs, or even at tickover/battery charging speed, is unlikely to do much harm if done hot. Which, of course, is rarely what is done when running the engine solely to charge batteries.
How cold is "cold"? My engine is raw water cooled and the thermostat opens at a ridiculously low temperature (40 or 50 C, I think!) - presumably to try and limit the ravages of hot salt water on the iron head. I've never had a problem with a glazed bore.
