Silent Lady
7500 Hours
We had a charter boat the other year with 7500 hours and it was running superbly
Beneteau 323 with Yanmar 3ym20
Small piston aero-engines, like the Lycomings used just about everywhere, have a design life between major overhaul of up to 2200 hours. Where they are used in helicopters (for example Robinsons) they are thrashed within a few percent of their maximum allowed for their whole life between startup and shutdown.
Entirely the other way round: car engines regularly get revved and worked to go up hills, accelerate away from lights, etc.
150,000 miles on a car engine is more like 5,000 hours than 2,500, unless the car never gets into a city or onto the M25 at rush hour.
And car engines are much more highy stressed than boat engines, typically producing at least 60-80 hp per 1000 cc - boat engines seem to be about 20-25 hp per 1,000 cc.
The motor boat forum regularly has people asking for advice on used boats and being told that - to quote a recent one - 75 hours on the engine is a bit much.
Modern car diesels should be good for at least 150,000 miles with regular servicing, which is probably around 2,500 hours. On the other hand, car engines spend most of their time running at perhaps 20% of maximum output and only get wellied occasionally. Boat engines - like aeroplane engines - spend a lot more time at high powers and so might be expected to wear out faster.
For example, out of their 5 cylinder 2.4 litre diesel they get anything from 107 bhp (45 bhp/l) to 213 bhp (89 bhp/l), which seems fairly close to what they get out of the road-going equivalents.
And I stick to my claim: a 100bhp marine diesel is likely to spend most of its life at 80bhp while a 100bhp car diesel is likely to spend hardly any time at more than 50bhp.
What "high powers" do you run your revs at?
2000-2500 seems ok on my car diesel & don't normally run my boats any higher.
Just a thought to chuck in to the equation. Weekend before last I took Sacha to Milford Haven from Pwllheli. Hardly any wind so motored all the way. Logged 17 hours on my NEW hourmeter.Lack of regular use I suspect. Also a tendency to run them for short periods esp starting and stopping again immediately to make sure all is well during winter lay ups.
Modern car engines probably wont have reached their first service interval in 250 hours.. esp petrol engines.
My Peugeot 406 cruises comfortably at 2000 rpm and does about 70mph. So if you multiply 17 hours by 70 mph it gives 1190 miles. Sachas engine did the equivalent of 1190 miles that weekend.
The engines which survive 150,000 miles are generally the ones with easy long distance high speed lives. But yes, "at least 2,500" would have been better.
We had a charter boat the other year with 7500 hours and it was running superblyBeneteau 323 with Yanmar 3ym20
Remember, though, that your car is probably running at 20 - 30% of full power while cruising at 70mph, while Sacha is probably at 80% or so.
150,000 miles on a car engine is more like 5,000 hours than 2,500, unless the car never gets into a city or onto the M25 at rush hour. And car engines are much more highy stressed than boat engines, typically producing at least 60-80 hp per 1000 cc - boat engines seem to be about 20-25 hp per 1,000 cc.
But that is not relevant to most small yacht auxilliaries. Kubota (Beta and Nanni) small engines are 479cc with outputs of 10 or 13.5. A 38hp has 1498cc. So specific outputs of between 20 and 25hp per litre maximum. Run at 75% means using 15-18hp per litre. Almost "vintage" outputs!
A few years ago, whilst phoning Al at BUKH [UK] Ltd to order something, I bemoaned the news that the DV10ME was no longer being made.
'What will I do when my 25-year old one needs replacing?' says I.
'It won't' says Al.
I like a man who has confidence in his company's products
(Not sure that applies to ROCNA's snake-oil salesman, though!)
Problems at 250 hours must be the exception rather than the norm. Plenty of 30 year old marine diesels still chugging away.
Not always so. My Yanmar 4JH3 HTE gets 100 bhp out of 1,995cc. The same block and head are used for for differents variants putting out between 56 bhp to 125bhp. So I would be cautious with that generalization. Turbocharging and intercooling can wring quite a bit of specific output out of a relatively primitive marine engine. There is a big range in specific outputs these days.
