Gludy
What you say supports the facts - there actually is a formulae - its the same as a mono hull displacment speed - the difference is that a displacement cat can go past the 'displacment speed' without as much penalty as a mono hull becaue the slimmer hull is generating a wave that is less powerful, and so require less energy to go faster - up to a point. After that point a planing mono hull would be better as regards efficiency.
"some 30ft semi displacement cats happily do 24 knots with small engines which seems to smash the displacement formula on waterline length."
I do not think that is right - they do not smash the formulae, the wave length genrated by the hull is the same and the formulae applies - its just that it requires less energy to go past that than is the case with a wider mono hull.
It really does seem that general conclusions from all that is interesting -
1. For most sized leisure boats 30 foot to 60 foot, Cats offer mid speed crusing, typically 10 to 25 knots that is very efficient compared to SD or planing boats. Displacment boats cannot practically do these speeds anyway.
2. The most useful cat hull is a full displacement one.
3. If you are going to add volume add it to the depth of the hull as only frictional resistance is added.
Your thread has been interesting as all this is new to me and I have learnt it all along the way - mind you I have had to consult an expert to get the info
