DavidTocher
The engine has always been a ready starter until recently. The
engine started to run very hot. I removed the cylinder and flushed
out flakes of rust from the waterways. I reassembled the engine
which started easily and ran cool.
The next day after 2 hours running the engine cut out as if the
ignition had failed. I checked the spark which was OK and replaced
the plug as a precaution. The engine restarted very reluctantly
and took time to build up revs and power. It then ran for about
another hour without any problems but had a reluctant restart.
I spotted a crack in the vacuum tube for the crankcase to
carburettor (operated the integral fuel pump)and replaced the
tube.
The following day it ran for 6 hours without problem but died on
idle when in a lock. I failed to restart the engine. The next day
it readily started from cold. The subsequent day it was reluctant
to start from cold or warm.The spark plug has always looked its
usual self i.e. black from all the oil (20:1) and I suspect the
grade of plug (L86), which I have always used, is running too cool
to keep it clean.
I did wonder about the ignition timing but the symptoms don't seem
to fit. Would a leaking cylinder/crankcase joint give me problems
like this? Any suggestions, other than replacing the engine, as to
the cure for my problem? Would an ultrasonic cleaning bath help to remove the rust?
tube.
to keep it clean.
