Daydream believer
I have had a calamity whilst filling my tank with fuel. I expected to add 5-8 litres of fuel, but when it got to 18 litres I guessed something was wrong. I thought I had miss calculated the hours. Then I decided to look down the filler to see if I could see if the fuel was coming up the pipe. Shock horror! the pipe had come disconnected form the filler & once the pipe had filled the excess had overflowed & gone into the bilges.
I removed soaked ropes & fenders from the locker, then I waited 24 hours to let the fuel drain through to form a puddle somewhere. Today I started to look for the fuel. I have no luck so far so suspect it may have collected under the shower tray. I will try using an oil extractor later to see if it has & if I can remove it.
The reason for my post is that it has not flooded everywhere & it is not a case of pouring bilge cleaner in to the bilges. I will be able to wipe dry any surfaces- when i find where the fuel went. I will probably use brake cleaner from a spray bottle.
My question is- can anyone recommend a suitable product that will help with the odour. A bit like Fabrical on furniture etc.
Or are there any pellets that might sweeten the smell - rather like toilet ones, but obviously not them as I do not want it smelling like a !!!!!!- . The area of the boat that is affected is extremely difficult to ventilate so just opening up is just not a suitable option. My bunk is over the top which does not help much
Would pet odour sprays work?
Any ideas please.
Any ideas please.
