Diesel range - Beta 13.5 HP
iainmillett
13 Jul 2001
kent
I have a new Beta 13.5HP in my Hunter 23' (just!) along with a 25 litre tank.
Given a moderate speed in fair conditions does anyone have an idea what the reasonable range of this set up should be?
Using the well known 20bhp.hours per gallon of diesel or 4.4 bhp.hours per liter and assuming that you use 5 bhp to drive the boat along then you'll use 5/4.4 litres per hour ie. 1.1 liters per hour. If you use 20 of the 25 litre capacity of your tank that's 18 hours range. You could well find that 1.0 litres/hour [4.4 bhp.used] would be sufficient under good conditiond which would give you a 20 hour range.
Most helpful - I'll use a factor of 3/4 to express my full tank in hours - should be enough to get us going! Now where's the sun.......
My D850 Kubota uses <2.5l/hr @ 2,750rpm, so I'd expect the Z600 (which I believe yours is) should be a whisker over 1l/hr. Best though, is that you can carry a 10 litre container and extend range by almost half again!
