eastlaked
Active Member
Hi Guys,
I noticed a leak where the pipe meets the injector. I didn't look too close as I didn't want to risk getting squirted with high pressure diesel. But it looked like the leak was at the pipe-nut join rather than a obvious split or hole in the pipe. I tried tightening, but no luck it still leaked.
All the other injector pipes look newer, so I guess this one has had its day. Its a Thornycroft T80 (D), so has had 20 years of vibration. I recently ran it hard to catch the marina lock, so that may have been the final straw!
I guess the options are:
(A) buy a new pipe, but I tried the usual web sites but none in stock at ASAP and the parts not mentioned on the Thornycroft site.
(B) Do I have to buy a Thornycoft specific part, or is it something that a garage / workshop just makes (ie bending a bit of new pipe to the correct shape)?
(c) Should I dismantle the joint, remove the copper washers and replace them or heat cherry red (are there copper washers? Hang on, it must be an Olive ????) ???
Some guidance welcome!
Thanks,
David.
Thanks,
David.
