jon and michie
Right as there has been much debate on this subject that seems endless and is like marmite either a branded make or unknown Chinese version - I thought I would post my install that I planned over lockdown period and researched before jumping in.
As a sort of foreward to this post This is a Chinese heater that I bought on ebay for £89 and I purposely got it in a aluminium casing was installed in such a way that if it ever failed all that would be required is to just remove the heater unit and install the new one
Here goes
Here was part of my planning with ducting measurements - Because of the space the heater had to be suspended - This was done using high temperature gasket paper to mount the custom bracket (which I had 2 lying around) This was to stop any transfer of any heat to the above GRP.
The Hull Skin fitting was fitted again with High Temp gasket paper and I fabbed up a backing plate for it to be bolted to - the fitting was well above the water line and had high temp sealant added to protect the outside grp from water ingress.
The Ducting was 76mm diameter (the planned drawing says to be reduced but I stayed with the one size) 2 ply silicone which could take up to 260 degrees C - the Ducting insulation I made up from High teperature insulation rated at something like 2000 degrees C
Here goes
