aquaholic
So the engine is now out and I need to look at the fuel delivery side of things, I have had the boat on the hard for two years, and I know she had been sitting for 5 years previous to that so I suspect the diesel is infected with the dreaded bug. I have decided that i would prefer to replace the tank as there is no way of properly inspecting or cleaning it. I think it also makes sense to replace the fuel lines at the same time.
So a few questions if you dont mind:
1, Any suggestions on where to get a new tank? would like to keep to a horizontal one, plastic or metal?
2, Fuel lines, can i replace them all with hose as opposed to a mix of copper pipe and hose?
3, do the fittings have to be pressed on or can you use another connection method...clips etc?
Forgot to mention that the VP2003 is being replaced with a VP2003T
Have attached a few photos to give an idea
