vas
hello all,
a few years ago I started searching for cheaper/diy alternatives to Maretron regarding fuel flow monitoring.
After many setbacks, I ended up helping a company doing diesel fuel monitors for trucks open up to the marine market.
I hadn't realised that fuel monitoring in HGV is such a big business. (I guess mainly to help logistics companies sort out diesel costs and not be stung by drivers?)
Anyway, got two 250lph devices foc for testing and feedback. Each one is two separate measuring chambers with in and outs with a common electronic unit on top with NMEA2K cabling. Similar to Maretron and apparently v.accurate as well.
So to cut a longish story sort, and after 3-4 incarnations of the s/w in order to properly sent the right NMEA2000 sentences, identify port/sbrd engine, etc, I now have decent fuel flow data for both engines. Garmin (and all others that support fuel flow data) does some lt per nm calcs as well which are really helpful.
Following are three videos I took on Sunday evening coming back to port on flat seas, with a bit of growth at the places I've not put proper coppercoat this year (will do in spring), with trim tabs not functioning as in extending fully, and clean props (which really impresses me after almost 4months in the water, but I'll do another thread on that later). Also note that GPS vs Autopilot heading is almost 30degrees off (when going Northish, but spot on when going Southish...), need to do the a/p config thing again (turning around in flat seas etc).
Fins were parked in the middle and slightly offset in most videos (was mainly playing with them, but will do more testing during the next couple of weeks)
Now what I'd like your opinion is if you feel that the values reported should need any further smoothing. The guys doing this h/w never bothered with presenting the data realtime as it's basically a logger. So they are happy to do the calcs (and they are indeed accurate!) but not so sure how much to smooth the data.
Note smoothing or not, wont affect the overall values logged/reported and hence the overall trip fuel values.
Note2 during these videos, I had already been travelling on that speed for at least a couple of mins before taking the shot so flow and return was theoretically settled on the conditions...
https://youtu.be/CCP8yinDmyE (only two embedded videos allowed apparently, so third just a link to youtube)
there's another one at 6.5kn burning 1.1lpnm or so and I somehow missed my favourite speed of 7.5kn but not much point boring you to death...
so, should they smooth a bit more, or not?
If you do have fuel monitors how stable are the values? I'd guess that ECU based monitoring would be more stable, not sure on mech. engine ones though!
cheers
V.
PS. I personally think they should smooth them more
cheers
V.
