MagicalArmchair
Because you can never have too many threads about the same thing (especially something as exciting as fuel filters), so apologies if I have missed something in my trawling through all the old threads!
Triola, inexcusably, still has only a water separator and no sensible primary filter before the engine filter. This winter the tank is coming out to get scrubbed, an inspecting hatch will be added to that, all fuel pipes are being replaced, and the old CAV water separator is going to be replaced... with something...
You go to SSL Diesels, you can get a self priming filter for less than £30: https://www.ssldieselparts.co.uk/primer-with-filter-small-glass-bowl-p-932.html
Surely this has got to be the filter to go for? Why pay 1,000% more for filter elements for the same micron of filtration?
I can't help but think I must be missing something that makes the Racor worth that uplift?
Edit: ASAP when answering this question state: The Racor filters feature Aqua bloc protection which will repel water away from the element and the elements contain a lot more media (paper) so have a larger surface area than the CAV filters. All in all they provide much greater protection than using a CAV filter
- Racor is the obvious option, however, at £80 to buy, and more importantly £20 per cartridge replacement (!!), http://www.asap-supplies.com/engine...ilters/racor-120at-diesel-spin-on-fuel-filter
- CAV replacement. Cheaper to buy at £30 and critically cheaper to replace the cartridge (£3 per cartridge). The 296 is 10 micron I think? http://www.asap-supplies.com/cav-type-fuel-filter-water-separator-302003
