Sneds
Hope some people may be able to offer some advice/help?
The following is the result of the oil analysis report carried out on a 2001,
535 hours Yamaha ME421 6 cylinder turbo diesel.
What does it all mean? Are we talking serious stuff here? Anyone know how much it would cost to rebuild this engine?
I have been told it is premature wear but a mechanic friend told me these engines run for ever!
Should it stop me buying the boat? The vendor has offered a reduction in price, as yet unknown, how much should I ask for?
Prior to this report the surveyor said the engine seems as sweet as a nut, starts easilly and pops the boat, a Sealine 260, up onto the plane with little effort.
All comments gratefully recieved and thanks in advance.
Cheers
Iain /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
Sample No. P071690-001 Report Date: 12/04/2007 Unit ID
Description St Engine
Customer Mr. Simon May Make ME420 S/line
Boatcare Yacht Services Model Yanmar
120-121 Saltmakers House
Hamble Point Marina
Hamble Oil in Use 20w/40
SO31 4NB
IMMEDIATE ACTION****IMMEDIATE ACTION****IMMEDIATE ACTION
SYMPTOMS: Note levels of: Sodium, Iron, Aluminium and Copper.
DIAGNOSIS: Possible coolant leak into lube oil system. Indication of component wear,
predominantly piston/bore wear.
ACTION: Engine examination recommended. Change oil.
Date Sampled 03/04/2007
Date Received 05/04/2007
Date Tested 11/04/2007
Unit Life
Oil Life (hrs) 100
STATUS CRITICAL
PHYSICAL PROPERTIES
Viscosity @ 40°C cSt 95.3
Water Content %wt 0.0
Total Insoluble Matter %wt 1.8
SPECTROCHEMICAL ANALYSIS
Iron ppm 117 *
Chromium ppm 7
Aluminium ppm 96 *
Molybdenum ppm 7
Copper ppm 47 *
Lead ppm 4
Tin ppm 3
Nickel ppm 2
Silicon ppm 18
Sodium ppm 727 *
Boron ppm 12
Vanadium ppm 0
Calcium ppm 2715
Phosphorus ppm 1116
Zinc ppm 1385
Magnesium ppm 172
Barium ppm 0
Cheers
Hamble Point Marina
SO31 4NB
Unit Life
Oil Life (hrs) 100
STATUS CRITICAL
PHYSICAL PROPERTIES
Iron ppm 117 *
Chromium ppm 7
Aluminium ppm 96 *
Molybdenum ppm 7
Copper ppm 47 *
Lead ppm 4
Tin ppm 3
Nickel ppm 2
Silicon ppm 18
Sodium ppm 727 *
Boron ppm 12
Vanadium ppm 0
Calcium ppm 2715
Phosphorus ppm 1116
Zinc ppm 1385
Magnesium ppm 172
Barium ppm 0
