sgr143
It's generally said that running the engine for long periods not under load gives rise to the bores getting glazed. Now I'm quite happy to accept that as a matter of experience, but I am still a bit puzzled as to just why this happens. (I'm an academic metallurgist, so I worry about this kind of thing for a living...).
No load means somewhat lower gas pressures in the cylinders, but I can't see what difference that makes. I can't see that it would make any difference to the pressure the rings exert on the bores. The engine would run cooler for a while, but it shouldn't take that long, loaded or otherwise, to get up to the temperature set by the coolant thermostat; after which, no difference?
So I'm a bit stuck for an explanation. Any ideas?
Steve
Steve
