kieron riley
Active Member
Hi this engine is fitted on our little cruiser and the hot side of the turbo has seized up if we can I d the engine we may be able to fing a replacement part , so any ideas . Thanks for reading . Kieron
You can't post pics as a new member until you have put up a number of posts.
Thanks for that , I don’t see the first time I tried but I have just tried again to download and I’m told the file is too big? Well now time lost . I can’t put the photo on
I have found a way of ( I think) identifying the turbo, it’s an AI on google . It tells me that the turbo isHe has 60 posts and 6 years on the site -that's not the issue.
As he reported. his file size is too large, and needs to reduce the size or quality of the photo.
No, it definitely says "New Member"He has 60 posts and 6 years on the site -that's not the issue.
As LittleSister says, member for nearly 6 years with 62 posts.No, it definitely says "New Member"
Not true. Limit for newbies is on PMs.You can't post pics as a new member until you have put up a number of posts.
Sounds like the wastegate is jammed, bit surprized they couldn't free it.Hi and good afternoon all. I have found a way of identifying the turbo using AI on google . It tells me that it is a Mitsubishi
tdo25l-05g ( hope I got the o,s and 0 correct)for a lombardini industrial engine . Specifically designed for a Lombardini LDW2004/T and 2204/T industrial engine . So I hopefully now have something to work with . So thanks very much for reading and reacting with all your help any suggestions .We have actually had the turbo repaired but the hot side with the pressure relief valve is seized and the turbo place has tried to free it but with no luck, so what we will need is a replacement hot end , or a complete new turbo , I will start looking now, but have to admit that most things that go right on a computer is more by good luck than tech savvy to me . So if anyone can still help in any way I will be most grateful. Thanks .Kieron
