Farmer Piles
Interesting that the D4 is designed by Deutz. Deutz engines are used extensively in agriculture and very well regarded for build quality and punch.
if your looking for a boat with an inboard then shaft only as you will regret getting one with a outdriveHi, new to forum so you can answer my dumbass questions
Looking at a couple used boats, quite fancy a diesel inboard over a petrol outboard to save on fuel
One boat that takes my fancy has a mercury 2.8l qsd 220hp with bravo 3 outdrive,
The other boat has a volvo d4 225hp penta
The boat with the mercury is to use a term very loosely 'cheap' im wondering if its because of the engine
Anyone have experience with the above engines, maintenance, parts availability, what i should look out for
Dan
its more then just the cost of fuel, i dont like the thought of 250litres of petrol on board should a fire electrical or otherwise happen its going to be a big bang...not sure how likely that is to happen but at least with diesel im not a floating bomb with my kids on board
If its shaft can you steer in reverse using the bow thruster? I use reverse steering quite a bit with my current outboard boat. If you have shaft and get something wrapped around the prop i assume you have to go swimming to clear it?if your looking for a boat with an inboard then shaft only as you will regret getting one with a outdrive
unless of course you are only going to use the boat in total fresh water.
