NickCharman
This winter, I have got to that time. To change the engine. I could do the normal thing and replace the 4-108 with a Beta 43 hp or similar replacement.
But I have read about installations where the engine is configured with a generator, running nearly silently in a really well sound-insulated box, on wobbly soft mounts, running at peak efficiency rpm, generating electricity (AC 110v presumably?) and the propulsion is electric motors on the shaft, and therefore also magically quiet. Side benefits of having loads of spare electical power for fridges, watermakers etc. Also theory says that if the engine is running at peak efficiency all the time, it can be smaller, lighter and be more fuel effficient than a normal engine/gearbox/shaft solution.
How practical is this really? No doubt possible, but is the expense so far outside the normal solution as to make it impractical? How does one scope up the pwer requirement?
Any one got experience of this? Or forget it, and trudge the well worn paths?
