RJJ
Hi everyone. Having run perfectly for three years, the engine cut out today (loss of revs then quietly came to a halt) during a spot of bumpy motor-sailing. On inspection there is a little gunge in the water collection bowl below the first filter, which wasn'tthere when we set off. We diverted to an anchorage and I will address it in the morning. I would really appreciate thoughts on the optimal sequence.
1. Change filters and try to start engine.
2. If no success, check the fuel lines and try to unblock.
I am guessing 1 will likely work. If so, then should I
3. Stock up on filters, double dose with fuel set, and soldier on. Or
4. Proceed to tank cleaning and all that jazz.
Anything else I should do? Many thanks.
