geem
We were fortunate that it's been pretty sunny recently and as we head into summer the sun is higher. In the winter I suspect we may need to make water on the generator so I won't know the answer to that until November/December. We certainly won't be ripping it out.told you that you wont need the generator, didn't I![]()
I have just ordered another 200w of solar that I will use as roving panels for when we are at anchor or fix them to the sprayhood when on passage if we need the extra solar. I will also build a second smaller lithium bank in November and remove the Trojans so I have some resilience to a BMS failure without having to carry the heavy Trojans.
I will parallel up the two lithium banks. This will be handy to cut the inrush current on the BMS mosfets as well. They may last longer. But yes, you were right. Gas and generator use is much reduced
