Reptile Smile
Hi all,
Your advice would be gratefully received.
I've bought a 'new' engine, and have been out with it twice.
The first time it started straight away in the mooring. Good stream of cooling water. Went out, sails up, came back. On the way back in I started it - it was fine (though sounded a bit funny). I put it into gear, and dropped the sails. The engine cut out, and wouldn't restart. I swore. We put the sails back up. In the end, I noticed somehow (god knows how) the fuel tap was off. I pulled it out, it reluctantly started, we motored back in.
I have no idea whether the fuel tap got knocked as part of the frantic rush to restart it, or whether it was part of the original problem. I certainly think part of the issue (possibly unrelated) was it was flooded.
The next weekend (this weekend), I started it in the mooring. It was fine. Good stream of cooling water. We motored out. On the way back in, I started the engine. It started (though was grumpy), though sounded a bit funny. I thought the problem might be low fuel - put more in , pre-mixed with Wilko's finest (3 quid a bottle) which was different to the last brand - 10 to 1 (the original owner said it was ten to one, but slightly less (don't know whether he meant less petrol or less oil and will get back in touch with him to check).
I put it into gear, and it cut out. It then simply won't restart. Sometimes it sounds like it's firing, but it's not nearly 'coughing' into life.
I then resign my self to sailing in. Sails up. Wind drops right at the mouth of the mooring. I swear. Tide is carrying me past. I give the engine one more go, and it starts. In neutral it's fine. Putting it into gear makes it grumpy. I have to give it full beans in gear, but it takes us in and home.
1) Why is the problem on the way back in? Might it be related to 'dragging' it in the water behind the boat (I didn't bother to lift the pivoting transom bracket up because the tilt bracket is knackered, so I just dragged it behind (and both times had had a fresh wind and therefore plenty of drag just before trying to start it on the way back in). Might water have got forced somewhere? Might this be related to why it maybe drains when left between trips and therefore starts fine in the mooring but not when restarting it when sailing?
2) Wilko's two stroke oil. Discuss. [8m]
3) Flooding. What do I need to know and how do I avoid it? How long between running a Seagull will necessitate choke? (An hour? Two? A day?) Should I always start it on full beans, or half way, or just keep patience while I find out what it's happy with? Should I always 'tickle' the carb? Or not if it was only an hour since it was last started?
4) Any other diagnoses that strike anyone? I was bang on the money of 10 to 1 as far as I know - how tolerant might it have been to errors in this?
Many thanks in advance for your collective thoughts...
