LynneC
Hi there,
I am planning a complete 12V system re-wire of a Fisher 25. I've done extensive research, planning & documentation, & the maths is no problem, but one piece of the puzzle is missing from all the books & magazines I've read - it's this:
Suppose you have the following circuit (simplified as an example):
House battery with 2m cable to +ve bus bar
+ve bus bar feeds two 10W lamps (both 5m away from the bus bar)
Negative return from both lamps to -ve bus bar
-ve bus bar return to battery
All the volt drop examples I've come across are simplified - i.e. "measure the distance from the power source to the appliance, and do the maths" - they don't clearly state what to do if your circuit includes bus bars. When spec'ing the positive cable from bus bar to lamp, is the outward cable run 5m or 7m? If you use 5m & end up spec'ing quite thin cable, might you drop your full 3%/10% voltage allowance through that bit, then drop a further % through the run from the battery to the bus bar, and end up dropping too much across the whole circuit? And when spec'ing the positive cable from the battery to the +ve bus bar, is the outward cable run 2m & the ampage 20W (the sum of the appliance wattages), or what?
I fully intend to get my plans, once complete, reviewed by a proper sparky, but would like to get as far as I can before handing over to him, so appreciate any/all advice.
Cheers
Lynne
Cheers
Lynne
