Coaster
I have decided to add a stern gantry to a 34' sloop rigged sailing boat. Having mocked-up the approximate shape and location using plastic pipe I now need to decide on an exact specification.
The gantry is to support a Garmin GMR 18 radome (7.2kg), 2 gps antennae, a navtex antenna, some photovoltaic panels and (probably) various other lightweight items. I intend to have twin tubes, parallel with and about 200mm from each other.
The gantry width, at the top, will be about 2100mm. At the base the width will be about 2700mm, with the tubes rising vertically from base plates just inboard of the existing quarter rails. From the level of the top quarter rails the tubes will slope inboard, hence the difference in width between bottom and top of the gantry. Short horizontal pieces will link the main tubes at about 500mm centres.
I intend to fasten the plates to the deck using M10 through bolts with substantial backing pads of 18mm marine ply. In addition the forward bolt through each plate will be attached by "L" section s/s brackets to an adjacent bulkhead.
That's the plan.
I would welcome comments on the most appropriate tube size for 316 grade stainless steel. (The quarter rails are 25mm diameter). I'm concerned about the top of the gantry sagging, especially if I mount the radome centrally. Should I choose a more complicated design, to stiffen the top?
Help, please.
That's the plan.
Help, please.
