rockstar1234
N/A
I have always wanted to sail a boat like a 2.4 Meter but with much higher performance. I suggested a concept years ago and wonder if anyone else has any thoughts on how to make something like this work or improve the concept.
The idea I had was to use a molded "wing" that would have ballast slide inside it to give large RM-similar to a two handed dinghy where one of the crew is on a trapeze. The ballast could be moved by hand, foot power or electrically. The boat might have a small fixed keel. The ends of the "wing" would be slightly larger in section to provide extra buoyancy. Each side of the wing would be supported by a "trapeze" wire making moving the whole wing(and the ballast inside it) fairly easy since it all moves horizontally.
The idea is to sit in the boat like a 2.4 meter but plane(or foil depending on design) early and fast.
I'm interested in any ideas that would accomplish this in a relatively small POSSIBLY self righting monohull....
