Depth Sounder fluid?
pete32
2 Jan 2007
Hello
My depth sounder started to only work on a starboard tack, chased all the connections and still nothing, opened up the sender unit and found some liquid in it, not thinking I cleaned all this up then thought afterwards that maybe this liquid was important as a conductor between the unit and the hull.
Was I right to think this? Does anyone know what the liquid is so I can fill it up again?
Cheers!
RestlessL
6 Apr 2007
Solent
You need something that (1) doesn't evaporate too quickly (2) doesn't absorb air bubbles and (3) won't freeze.
A light mineral oil will do, as would olive oil. Airmar recommend propylene glycol which chemists sell as KY lubricant.
J
maxi77
11 Nov 2007
Kingdom of Fife
There usually is a significant impedance mismatch between echosounder transducers and air, hence the liquid filled container. Water is fine, the sound is intended to get into water as it is, but mat use castor oil because it does not evaporate. I have used water mainly as it works and is cheaper.
oldsaltoz
4 Jul 2001
Australia, East coast.
Transducers are fitted in oil baths so they can swing and point to the bottom and display the depth below the hull even when heeled.
You can use water or oil, we used baby oil, but just about any oil will do, it only has to keep the air from the bottom of the transducer.
Hope this helps.
Avagoodweekend......
aitchw
18 Feb 2002
West Yorkshire, UK
The moulded in cable on mine is so stiff trying to get the thing to swing would be a major headache. Don't know anyone who bothers.
maxi77
11 Nov 2007
Kingdom of Fife
Hope this helps.
So your transducer is in a bath that will allow it to roll 45 degrees each way? AS I said it is all to do with accoustic impedance mismatch hence the need to get rid of the air whcih can be done with a number of fluids.
bobgosling
7 Aug 2003
Cuckfield, West Sussex, UK
I'm afraid you have been misinformed. Signal is like the wide beam of a torch, hence still accurately detects the correct depth even when heeled.
Baby oil works well, doesn't freeze or solidify. Doesn't react with the plastic and smell nice if accidentally spilled.
moody1
10 Dec 2005
Anywhere in N.Europe / Baltic that boat is
Castor Oil from local chemists - you can buy it in 100, 200ml bottles so buy 2. Keep one as spare to top up later.
Castor is used as it is a good compromise density between water and GRP to provide amn airless connection. The gaff about swinging in the tube is bunkum as most tubes are only slightly greater ID than the transducer head anyway. Castor is also an environmentally acceptable fluid.
EdEssery
5 Sep 2001
Berks.
Better than a liquid is a gel. I used Camcare Ultrasound Gel - same stuff doctor uses when he/she is doing an ultrasound scan. It's designed for the purpose and is available through a good pharmacy or on-line.
Ed
