flaming
That's what I suspected, and it's where the Dehler CWS system on mine differs, because she was never designed to be raced.
I have only 2 coaming winches, one either side (not in front) of the wheel, and they handle the following control lines. Starboard side: Main halyard, mainsheet, jibsheet, furling line. Port: Reefs 1 & 2 (single line), jibsheet.
This means I stay behind the wheel for almost sail management. The 100% jib is virtually self tacking, sheeting inside the shrouds on track cars on the coachroof.
The winches on the coachroof handle all other lines and are maybe used 3 or 4 times in a season when the cruising chute is deployed (I dump the main in gusts with the sheet, not the rod boomvang).
I can see why the new boats have the additional coaming winches, as they are all fast and may be raced, which requires genoas and kites etc. and the builders fit them to address that market.
One or two D35CWS' have been raced, but they're not designed as such and need modification (no genoa tracks, no genoa winches).
As I said in my ealier post, some of the larger sisters (37, 41DS, 43) have the same layout because they are designed for cruising.
So I'm still stuck for something on which to splash the kid's inheritance.
I suspect that the reason the CWS system dissapeared after a while was that it solved a problem that wasn't really there - and added in quite a lot of friction.
For example, on My dad's Dufour 40 - also designed solely with cruising in mind, the only lines that you list that are dealt with at the companionway are the main halyard and the reefing lines. And to be honest, the companionway is the ideal place for this, as you can wedge yourself in and benefit from the sprayhood.
The Genoa winches are then within reach of the helm, as is the furling line.
