Darrel_Walters
Hi
Looking for a little guidance
This winter, I had all new rigging for my 38foot 10 year old boat.
over the last couple of months I have noticed that my Lewmar hatch, 14 inches aft of the mast had started to leak, as the hatch and the others were crazed I decided to purchase all new one and go about the task of changing them.
The stern one is fine then I took the amidships one out to find that the deck had convexed across the hatches leading edge to the mast, The thickness of the GRP in this area is approx 8 mm but you can visually see support in the GRP for the mast etc under the head lining. it then thins down to where the hatch is.
I contacted the sail company who rigged the boat for me and they had advised that they had tensioned the mast to between 12 and 14% of the breaking strain, I had mentioned to them that the deck had bowed as mentioned above, but was unable to suggest if this would be deemed OK or if there is failure of something.
I have now fitted the new hatch which in this case now uses 5 and 6mm bolts instead of screws, this has reduced the bowing to approx 4mm over its 500 mm width. You can noticeably see a slight bow in the hinge side but the hatch seems to be working fine and sealing OK.
I know you have to be careful with deck stepped masts and I know you should not over tension the rigging.
Is what I have noticed normal or does anyone have some sound advice to belay my concerns
Many Thanks
Many Thanks
