KevO
Having received such good advice re gelcoat etc, I'll chance my arm again...
My NTM Hustler has 3-tone uppers. The original white gelcoat survives in the cockpit, the hatchway assembly and around the sides of the coachroof. In the cockpit area are a number of poorly completed repairs where previous instruments and fixtures have been removed and the screw holes etc glassed over in various mis-matched tones of white and with varying degrees of smooth finish. It could do with a coat of suitable paint once I have tidied up the surface.
The deck area and the top of the coachroof has been painted (?) with a light grey, slightly satin, finish (def not hi gloss anyway - actually, to the touch it feels just like the unpolished white gelcoat). It has worn almost translucently thin in some areas and the white layer beneath is showing through.
Some areas of the deck and coachroof have a non-slip texture which has been painted over in a light blue which I dislike (a lot
Boat is outside in a boatyard. I cannot afford to get it all fettled and sprayed up by a high-falutin' profeshnial. What compatible DIY paint options should I explore for a long-lasting solution.
