On a GRP deck, the hard part for painting it is the area that is not anti-skid and supposed to look smooth. These areas are better to be painted with a spray gun if it is a 2 part polyurethane that is the most durable paint for the job. 1 part paints are also available and can be applied with roller and brush but i am not sure of the results.
For creating the anti-skid areas there are a lot of options and probably it's the easiest part.
Great job you did, I ll read in detail thanks for sharing!Trouble is, if you want to use 2 part paint, you can't apply it over the top of 1 part paint, meaning you would need to strip it right back. I did Triolas decks (the last boat) with 2 part paint - it looked amazing, but it was the hardest job I did on that lovely boat, but also the most rewarding. I wrote up a full guide below, which may be of some use if you are contemplating it!
Paint your deck outside in winter - Triola - Albin Ballad #50
P.s. I applied 2 pack with a brush and rollers and it went on just fine with a great result. Spraying 2 pack is a non starter as it requires an air fed mask, breaking bad style
P.p.s You don't need to go right back to the GRP, just back to the old gelcoat is fine.
You can't use an epoxy paint.
Although epoxy resin is durable in other ways, unfortunately, it will break down in direct sunlight because its chemical structure becomes unstable when exposed to UV light
Is Epoxy Flooring UV Resistant?
I be doing mine soon and I'll us polyurethane. I'll mask everything off and roll the sand/paint on. I'll roll and tip the shiny part.
My paint supplier can supply three types of hardener:
- One for spray painting (very quick acting)
- A hardener for brushing (maybe used for fairly cold weather.
- And a hardener for hot weather but slow enough acting so it give you time to "tip" before it "goes off"
