MagicalArmchair
As you may already be aware, I'm about to dive in to repainting my decks. I am using International Perfection (over International InterProtect and Perfection Primer). I am somewhat concerned the result will be too glossy - there is a matting additive that can be used. I figure a very shiny reflective deck sounds like a bad idea.
http://www.yachtpaint.com/gbr/diy/products/special-products/polyurethane-matting-additive.aspx
This is a ballad with the same paint scheme I'm looking at - looks quite glossy!
Do you add matting additive to your deck paint?
edit: The technical docs around the matting additive don't make very good reading!
"Polyurethane Matting Additive will provide a reduced mar-resistant finish and therefore should not be used on walkways
etc.
When used with Perfection, the addition of Matting Additive will reduce opacity, hiding power, of the product, so it is
important that the necessary number of coats of unmatted finish has been applied first.
As with all types of reduced-gloss coatings, the finish will not have the same stay-clean properties as a full-gloss
coating."
etc.
coating."
