Shiver Metimbers
I have limited space on the coach roof due to its profile to fit deck organisers, would there be a problem with mounting deck organisers 3 high?
The top tier would be used for reefing lines. The bottom layer Main Halyard, out haul and spinnaker halyard.
I see you have a 312, so the reefing lines would require a fair pull; apart from a re-think on the 3 tiers ( sounds excellent for trapping feet, & adjustment marks on the lower lines would be difficult to see ) would it be an idea to keep friction loads as low as possible by using ball bearing blocks in the rest of the set-up ?
Is it my arithmetic again or is that not just the usual two layers, (BTW the outhaul and spinnaker halyard should be less stressed than the reefing lines)
I am a fan of 2 line reefing too.
Still, as the average organiser is 4 sheaves ( or are you going for less, hence triple layer ? ) that would give 24 lines aft, which is on the comprehensive side.
...it has to be 2 x 3 and a 1 x 2 ...QUOTE]
Be very careful to check that the mounting bolt centres are compatible.
I renewed them about 2 years back with Barton 16mm so all I need is longer mounting bolts and a couple of Barton two sheaves.
Renewed them about 2 years back with Barton 16mm so all I nead is longer mounting bolts and a couple of Barton two sheaves.
