fastjedi
Sometime over the next 4 weeks I will be fitting 6x new pre made 6mm teak panels into an 9mm GRP recesses. Having done that, I will be caulking the 4mm gap between the teak and GRP .... all flush when complete.
I understand I would apply the caulking, allow to cure and and sand back if I was working between two teak planks. I am not so sure this is the right approach when working to a GRP edge?
- The GRP edge rolls into the recess / is not as consistant as the edge of a plank
- I doubt the top edge of the teak panel will be perfectly aligned with the GRP everywhere
I guess the alternative is to mask off the teak and GRP, apply the 290DC and then dress with a knife of similar to get the final finish.
Thoughts?
Thoughts?
