Decent mini washing machine?..
Oscarpop
31 Jul 2011
Kent
Still trying to work out whether to fit a normal washing machine to the boat for liveaboards sailing, or go with a portable one.
The third option is to go with a good quality mini one. However these only seem to exist in he states.
Does anyone have a source of a good quality small washing machine , that is not one of those plasticky things you get on amazon?
Cheers
Baggy
21 Mar 2005
suffolk
unless you can produce a lot of Amps... :rolleyes:
this will surfice for washing shorts, tee shirt and undies
hope this helps :)
vyv_cox
France, sailing Aegean Sea.
coxeng.co.uk
I assume you mean a Wonderwash? We have owned one for well over ten years and used it a great deal. Jill reckons it gets clothes cleaner than the all-singing, all-dancing one at home. It can be a little labour intensive due to the rinsing required but otherwise no problems at all.
coopec
N/A
23 Nov 2013
I bought a mini washing machine off eBay for about 40 pounds. I don't know whether it is decent because I haven't tried it at this stage. But it is 240V so if you haven't got that you would need to install a small, cheap inverter which could power a bread-maker as well for example. These machines are very light so I'll operate it in the shower using the shower rose to fill it and empty it down the shower recess. Here is a selection from eBay
http://www.ebay.com.au/sch/i.html?_...&_nkw=mini+washing+machine&_sacat=0&_from=R40
vyv_cox
coxeng.co.uk
Washing the clothes, either manually or with a small electric machine, is the easy bit. It's the rinsing, wringing etc that is labour intensive. A small portable wringer would be the best contribution but there don't seem to be any.
rogerthebodger
3 Nov 2001
I made a small manual ring roller some years ago which had 3 rollers made from steel tune and mounted on plummer blocks that is almost the same as a washing wringer/mangle.
http://www.gzhch.com/en_plate.html
BTW I fitted a samsung toploading washing machine that I can run from my inverter using cold water washing power works great and it also spins the clothes dry enough to just hang out to dry completely
coopec
N/A
23 Nov 2013
These washing machines are twin tub so rinsing and spin drying are not a problem. I have a hanging locker in the shower/toilet area and as this has an exhaust fan hopefully that will dry clothes.
vyv_cox
coxeng.co.uk
The first one in your link, for your quoted price of £40, is only a washing machine. The twin tub ones are far too big to be accommodated on my boat, which is why we stick with the Wonderwash. A cheap wringer would be nice though, even the pasta maker kindly linked to by alahol2 seems to be on the pricy side.
charles_reed
29 Jun 2001
Agree 100% - even more painful with arthritis. Rather than a wringer, perhaps a 12v spin-dryer?
Obviously a niche market here
coopec
N/A
23 Nov 2013
OK so long as you are aware of them and considered them. Did you see the single tub one with a spin cycle? It measures Size: 38 *34*53cm
http://www.ebay.com.au/itm/Portable...84855?pt=AU_WashersDryers&hash=item484dd0f3d7
dslittle
7 Jun 2010
On our way
We have one of these and found it very good. Have now 'upgraded' to an electric 'bucket' to save manual labour. Will keep both until we see how new fangled electric contraption works out...
wiggy
13 Jun 2001
Portsmouth Harbour
To dry clothes on the boat we use an Eastern European tip passed on by my sister in law who's from Slovakia. Lay wet item on a flat towel, roll it all up and wrong it out,it works fantastically, much better than just wringing out on its own.
Buck Turgidson
10 Apr 2012
Zürich
How do you dry the towel?
Lubber
5 Feb 2015
Pipe dream or God's blessing?
I had a dream in which my 36' Hunter had an onboard washer/dryer but when I awoke and checked the specs again it was gone! But as God has blessed me with similar dreams in the past (a flat screen, hanging on the wall TV, long before they were a reality, for one) I thought I'd see what could be "out there" to make the Sea Sun Ticket a home for someone who owns none, YET!
(I DID warn y'all I was dreaming so this was a dream within a dream I s'pose - well whaddya expect from a guy who calls a bilge pump a sump pump :)
In any case, an Italian firm makes/made a combo unit (washer AND DRYER) "Splendide Model WDC12024" which operates from shore power but I can't find a dealer for it, so eBay may be your best bet for that.
ON THE OTHER HAND, HAIER makes "portable' washers, in 1 cu ft and 1 1/2 cu ft models which sell at Walmart from $229 and up, some of which include an iron for those of you who like your "undies" starched!
And, to match with that, Sonya makes a 3.75 cu ft dryer, also running on 110v, from Sonya Direct at $349 - $379
Well folks, I've done the brain work, now you if you can find a mechanic with the right size shoe horn to squeeze these options into your galley to do the brawn work you can wash your stuff with the same ease as you would at the local wash'n'go!
Happy sudsing
