scubaman
The background to the story is that ever since we bought the current boat, the worn teak on the bathing platform has bugged me. It’s teak veneer on marine ply and the ply was already showing at some places when we got the boat. As you’d expect, it hasn’t gotten any better over the years and as after last summer the veneer was pretty much gone, I finally made the decision of doing something about it.
The local brit boat dealer recommended a boat carpenter in Estonia, whom I contacted in the autumn.
A couple of weeks ago they came over to do the templates and partly due to time constraints we agreed that I’d remove the old deck. A lot of work it has to be said.
I’m having the bathing platform done and the side decks. I then made the decision, which I might regret later, of doing the cockpit only partially. The reason being that from the transom gate, the teak was worn through (as that part gets the most traffic), but other areas of the cockpit are still in relatively good condition. This is partly due to the fact that we keep carpets to protect the teak from the table and chairs. So as there was a seam in the rounding teak panel just where our carpeted area ends, I’m only having the part left to it renewed. The seam is just behind the the first fly step’s stb end. Also on the previous pic at lower left corner next to the 'L' shaped teak part.
I’m expecting color variance at first but also that it will even out after the first year. If not, I can always do the rest later.
There was some collateral damage as you can see in this pic. Should I put gel coat on these or just let the teak glue take care of it?
I went out and bought a Fein tool in the vein hope that it would help in the removing part, but it seems a chisel and a hammer are the only sensible tools for the job. Instead, the Fein tool did come up trumps in sanding the fly steps and the rope locker lids.
Any and all suggestions and remarks regarding the job at hand are welcome.
I had a long hard look at the synthetic alternatives but as the carpenter only works with real teak, that's what I'm having.
I’ll update this thread as my teak project evolves. The installation begins mid April.
