Bosun Higgs
N/A
Got to agree with Flaming about snuffers. Just too many bits of string to get tangled. Create more problems than they solve.
get the autohelm (or SWMBO) to drive whilst you rig the gear.
Turn onto a very broad (165-170 true) reach.
Put the guy in the pole, and set the pole to the height you want.
Open the spinnaker bag and return to the cockpit.
gently pull the guy until the corner of the sail is at the pole, but the pole is still at the forestay. Lock off the guy.
Set the sheet so that there is only a small amount of slack with the sail still in the bag, and lock it off.
hoist the sail with the halyard.
Gently pull / wind on the guy so that the pole comes off the forestay and the sail fills with wind. Continue to wind back the guy and ease on the sheet until you have the pole where you want it, and the spinnaker flying. Then tension the pole down.
now furl the genoa.
to drop is basically the reverse.
Unfurl the genoa.
Ease the pole to the forestay, whilst trimming in on the sheet until the spinnaker is fairly tight along the foot and not very (if at all) full of wind.
Fetch the lazy guy and run it down the hatch.
Run the halyard around a winch so that there's only 1/2 or 1/4 of a turn
Completley blow the guy.
Start pulling in on the lazy guy until you meet resistance - try and go along the foot, rather than up the side of the sail.
Once you can't pull any more sail to you, release the halyard - the part turn of the halyard round the winch should slow its descent enough to allow you to stuff the sail down the hatch without getting it wet.
And hey presto - one sail dropped without having to go on the foredeck. Magic.
That undoubtedly does apply to some multis and fast monos but it doesn not apply to all boats. For example on my boat you would have to go more than 20 degrees off a dead downwind course even to get the genoa to properly fill, and a bit more than that to get boat speed through the water as fast as goosewinged. Altogether different with, for example, a J109 flying a gennaker from a pole as I know from racing against them. Horses for courses
Poling out the tack on a cruisy chute.
Does it need to be a pukka spinnaker pole, or can something shorter and lighter be used?
At 20 degrees of the rhumb line you only need an increase in speed of about 6.5%, at 25 degrees - 10% and 30 degrees 15%.
There are few boats that won't achieve these figures and as I say you will have more comfortable and hassle free sailing.
What's all the fuss about cruising chutes (assymetrics) versus standard spinnakers?
I sail a cruising chute exactly as I would a performance dinghy assymmetric- hoist, sail, gybe, gybe, etc...
Do not go too deep and lose power to an inappropriately set main.. gybe and head up a touch to get the power on again??
Sheet the main in a wee bit hard for the circumstances- keeps clean air on the chute? Less clever over 10-12Kts, bit does help.
Dead downwind , if you insist.. either pole out the genny goosewinged or hoist a standard spinny. Less easy I will agree if short handed.
Non symmetric chutes are much LESS suited to dead down wind.
Me .. I'd rather be on a deep reach than messing with dead downwind...
Graeme
I disagree. Dead downwind ie goosewinged, my boat will go faster than it does on a broad reach until the wind is maybe 30 degrees off the stern. The reason is that the genoa is shielded by the main until the wind is at least 20 degrees off the stern and it just flaps doing nothing much. Masthead rig and not a lot of sail area.
What sort of rig do you have?
I sailed on a yacht two years ago with a cruising chute and running dead downwind we actually goose-winged. Don't know whether this is legitamate but it worked extremely well.
To dowse it gybe the main over and then its in the shadow again.
Did it ourselves yesterday, let the tack off a way and the main on the otherside keeps the chute inflated, dont need a pole in that situation.
