tymonk
Hi. I want to replace the VSR that came with the boat with a DC2DC charger to keep the 2 batteries (starter + domestic) separated and to apply an AGM-specific charging profile when the alternator is running.
The boat has an emergency parallel switch behind the 2 individual battery isolator switches. I emailed the DC2DC company to ask what would happen to the DC2DC charger if the batteries were paralleled in an emergency. They have said both positives and negatives from the charger should be disconnected to avoid the charger and batteries being damaged, whether the engine was running or not.
Does anybody have any solutions for this? Ideally this could be done through a single switch, and possibly integrated with the emergency parallel switch? I have sketched out a switch that would work (see screenshots) but I don't know if something like that exists. Alternatively, a quadrupel (8 pole?) isolator switch that would just need to be manually switched off before engaging the emergency parallel, but I haven't seen these for marine use. The most I have found are dual.
Any advice or suggestions would be much appreciated! Many thanks.
